RE: pull-pull rudder cable question
Thanks guys for the advice.
Actually there is another factor here. I called local hobby stores here and non had similar cable (steel cable). Also, I am not sure what type of fishing line I can use as a replacement.
Given this, can the streel cable break because of rudder tension at his spot? What are the chances:10%, 5%, or maybe 1%? or ZERO%!!!
Thanks again.
