RE: dented TP pack-Fixable?
WHOA!!!!!!!!! DO NOT USE A SCREW DRIVER TO TRY AND SEPARATE THE CELLS!!!!!!!!! METAL AND LIPO CELLS DO NOT MIX!!!!!!!!
If you plan on taking the cell off, please use an NON METALLIC object. Like a Popsicle stick or a plastic dull knife.
Metal punctures the cell and it will get ugly real quick. [X(]
And a tip. TP's can sometimes be a bugger getting apart. They use a really good double sided tape to hold the cells together. I've used gell CA remover to dissolve the adhesive to make em easier to get apart.
