RE: Comp ARF Valiant
today put my Valiant together to check alignments and work on the throws. This is a great plane and I love how it looks!!!! Also the build quality is great. For those of you that like the Jason Schulman scheme, they are still available even if it is not mentioned on the website so get one while you can!!
If I take the cockpit railing as my zero the plane actually came out quite flat. A little incidence on the wing (0.2 degrees) and no incidence (0) on the elevator halves.
I wonder about the incidence measurements, anybody did measure them?
Another question on the throws. In the manual the throws are mentioned for the snaps (23 degrees aileron, elevator 14 up, 18 degrees down, rudder 20 degrees). I wonder what the normal throws are.
Volkert
