RE: longitudinal dihedral
I thought I'd add a small bit of info that has helped me thru the years..most of you guys will catch this pretty quickly... whenever I design or use three vues, I usually set the fuse at zero and also the stab, I tend to put the incidence on the wing at whatever I chose 0,1.0,1.5 degrees I put it on the wing so that I can adjust it in the field or if it needs it at all. sometimes I even adjust the fuse and wing for the plane to fly level or slightly nose down..anyways the point is, how do want the plane to look when flying...it takes some research to understand all thats involved to get a plane to fly right... as stated previously in this forum there certainly is alot going on when your plane is flying.....
