RE: Transmitter Storage - Fuse Contact Corrosion
Always good to check and clean contacts on battery leads and spray with a little electrical cleaner like CRC to keep them clean. Have you ever had a TV control that worked intermittantly and you moved the batteries a little and thngs were ok for a while?
Always frustrating when we loose an expensive model and are not sure exactly why sometimes.
I live near the ocean. About ever two years the doorbell switch has to be cleaned!
