RE: Joining a V-Tail
When you cut out the teeth, you hold each half up at the angle you want the V-tail to have. I use 120 degree, so I just tape a 30-60-90 triangle to the backside. The triangle holds the angle while I push the tail into the bandsaw to remove the wood where the X's reside.
