the mc 4000 red button blue`s
I can't see anything obviously wrong. Try it again from scratch.
menu 2, switches, scroll to M1 the screen should show
Assign switches
MOMENTARY SW: M1
FROM SWITCH :SO5 up arrow
then in menu 1, timer/count should show
TIMER 1: M1up arrow
TIME : 00:XXXXXXXX
START: 00:08:00
RESET: AUTOMATIC (unless you want cumulative time, set it to manual)
Each time you press M1 the asterisk next to M1 up arrow should toggle on and off. If you want a beep each time you toggle the timer to reset/start, activate TIMER 1 with the top left button and scroll all the way up to co-pilot, choose TIMER 1 with bottom left button if required, and using the bottom right button set it to ON.
Harry
