RE: corona 2.4ghz DIY help
Thanks for the help, I really appreciate the reply, but Iam still confused. If I connect to the trainer plug, do I connect the signal wire to the "in" (#5) or the "out" (#3) pin? Also do Ithen have to have the trainer switch toggled to activate the 2.4GHZ module? Do I have to disconnect the 72 mhz board from the system somehow? I don't have an oscilloscope, but I do have a voltmeter. Ihave no problem finding the + and Ground, but I need to know where to connect the signal wire.
Thanks, JR
