RE: Byron Wedell Williams Racer Build
In regard to the control throws no I did not change them. If the cg is in the proper range the elevator is not that sensitive, nor are the ailerons and rudder. What I did do was mix in about 25% rudder with the ailerons on a switch. This allows for scale turns when flying race track patterns at large fly in events plus it makes the rolls into a barrel as opposed to a very axial roll that modern aerobatic aircraft demonstrate. This thing will do a pretty decent axial roll if that is you want but somehow the barrel roll seems a little more in keeping with it's time.
