ORIGINAL: frequent flyer
Hi David
I don't know what you mean by vertical? I lay the form flat to cut the cores, with the span of the wing between the two towers. It's a four axis cnc. I can cut to about 54'' max span and around 34'' max root .
I need a capacitor and it seems nobody has one. 10,000uf , 40VDC.
Epcos
(Conrad sells these capacitors in europe!)
Cees
