ORIGINAL: Zor
I still do not see where you said it was 2.4.
That is now irrelevant since you now confirmed it is 2.4 Ghz.
[/quote]
thanks for your search
but the problem in this thread is different as he is using 2.4g conversion kit corona
min is2.4g with TGY module
[/quote]
anyway regarding the range testing i made it in my 1st use and it was very good for me
my mistake that i didn't make it again after the antenna twisting i will try doing it with the original setup and i will cover this uncovered part by a heat shrink and test again
