Dynam Hawk Sky issues
order # yhst-1721025890263-168615 from Nitroplanes.com
My date of order was 1/4/11-I received around 1/8/11 roughly…I put the Dynam Hawk Sky together and went to adjust the throws…All is fine except the rudder. No matter how I try, it will cycle when the battery is plugged in and the transmitter is turned on, center for about 10 seconds (if that), and then go all the way to the right or left depending on whether the switch is set to reverse or not. From there it will not move. I also switched the plugs of the rudder and elevator and then the elevator does the same thing...It is my understanding that it is the RX and/or TX. I need to resolve this or get an RMA to return.
Thx,
Rob Cirnigliaro
