RE: Full Throttle Stall - HELP!!
how cold is it?
the motor may not be getting running upto optimal temps.
often to run in the cold people will wrap part of the cooling head with tin foil. that lets the motor temps rise a bit. dont go crazy with it. start by wraping just half of the cooling head.
its a good idea to have a IR temp gun. the duratrax ones are like $20-$25. makes it much easier to know how your motor is running if you know the actual temps.
