ORIGINAL: Makuku68
Does the Mikrokopters require soldering?
new kits yes, you would have to finish soldering small components on the board, like voltage regulators and connection pins. everything else like gyros etc are pre soldered.
then you will need to solder wires to the esc and also solder pins to esc's easy work
