Tracker III programing
What I want to do I dont think can be done.
Maybe someone has some suggestions.
I have had this tracker for years and love it. I do and have programed some functions like flap, flaperon, elevons and switch assignments. so I have been racking my brain (not much there) to do the folloiwng:
I have a plane set up for elevons, all is fine there. What I now wish to do is add just a little up elevator during the launch of the plane and then take it out once in flight. This would be kinda like reverse flaps (I thought)
To set up the flapperon you must select this in the wing mix selection, but I have elevons selected so I can't go that way.
I have mixed channel 1 and 6 and assigned it to a switch and this works fine but only 1 servo is activated.
I then tried to mix1 with chan 1 and 6, mix2 with chan 2 and 6, assign them both to one switch (A) and still only 1 servo (chan 1) is activated. Both mix's are set up the same as far as percentages of mix.
Now my brain is fried[&o]
Any suggestions?
Larry
