Okay lets see how I can best help you.
The first thing to replace is the ESC. Every thing else is okay for now
POOF no more heli!
Until you can replace the ESCI highly recommend you remove the plastic shrink wrap from the ESC and resecure the ESC with a couple of ZIp Ties.
Ihighly recommend the HobbyWIng Phoenix 30 amp ESC. It is what I use. I also use the programming card.
Makes setting up the new ESC very easy. Here are links to the ESC and Card
http://www.helidirect.com/hobbywing-...30a-p-4398.hdx
http://www.helidirect.com/hobbywing-...ard-p-4406.hdx
You will need to solder the Bullet connectors on to the ESC and you will have to change the ones on the motor as the Esky ines are very small.
Ihave not been able to find them anywhere, it is just easier to change them to a more standard size.
Here is a link to new bullet connectors.
http://www.helidirect.com/align-24k-...9a1-p-1177.hdx
Hope this info helps.
