RE: Q40 rules (radiators)
Correct. Just remember that 32mm is the minimum that must be met; you may be larger with your fuselage blending with no penalty. I would try to get the look correct, and then make sure it is within the minimums. It looks like you have the 3/4" clearance covered, just make sure both measurements stay within or larger than the minimums.
