RE: Balanceing the Yellow Aircraft P-47
Hi,
Let me see if I can dig out an old manual for the CG, but you should balance her with the gear up. That's the configuration in flight, and as mentioned here, the gear retract aft so you'll have a little bit of nose-ward CG when the gear are deployed. This is the best scenario.
