RE: Trouble getting motor to run
Thanks for the help. The lead from the motor controler is plugged into #3. Have the throttle and trim set to minimum and no go. I will continue to try. I am going to start fresh with a new set up on the radio. Do the end points and throttle curve need to be set up on the throttle? I click on the throtle curve and it is blank.
