RE: Damaged on arrival yhst-17210252890263-178908
You could head over to the CRM section of RCdiscuss if you want.
Frankly I'd just fix it.
You can use hinge pin joints, or CA ( but only use foam safe CA on one side , epoxy on the other ) inserts with a toothpick for re-inforcement.
Not only would this look as good as new, but it will be far stronger than the original.
Since it only takes a few minutes to do, it's less hassle than even writing up a post @ rcdiscuss.
