RE: E-Flite Mini Pulse XT Owner's Club
Last weekend's flights taught me the necessity of having exponential as an option, expecially for T/O. The plane came off the ground rather quickly, surprising me and I over controlled to correct a dropping left wing tip only to have the right pointed at the ground. All flights to date would seem to indicate that the factory set up gives plenty of throw , maybe too much throw. So last nite I programmed the DX7 Ele/Ail switches to provide Exponential. I probably did it incorrectly, as I have normal linear throw when the switch is in the "1" and expo when you move the switch up to the "0" position. It doesn't really matter as initially, I only intend to use expo for take off. May change my mind with some additional stick time. I have it set at 75% and would like to know what others are using?
KKKKFL
