RE: CA Model XURAMA BIPLANE Build Glow Powered
more...
Wing struts.
I will install the wing struts with 4 4-40 screws each, two on top and two on the bottom. I think this is stronger that just the wire and will hold better to the YS vibrations in time (is longer to put the airplane together at the field)
the wing has an internal plywood plate marked in the picture with masking tape, there is where the mounts will hold.
pics...
