ORIGINAL: 1ofmyfuns
Wow.....! very colorful scheme, yep you have spent a lot of time on that it looks like.....keep up the good work
Thank you i come from an automotive background growing up so painting and masking is part but did have some thin line tape that bleed but hell water colors are easy to fix, small fine point stiff brush and remove the mess up and remask the area. Had to do that with the silver and the orange break. the front nose will be white on it with a little black bleeding into that to seperate the front nose of it. Will be about another 3 or 4 hours till completed tonight. But ill post the final results tonight hopefully.
