Which DC converter for a Triton charger?
Not physical noise JustAnotherGuy! Electrical noise! A switchmode power supply is small and provides a lot of current by switching just like an ESC does. Problem is switching means it generates voltage fluctuations. And they're bad trust me. Stuff meant to run on 12volt DC might not behave too well when hooked up to a 12volt switchmode power supply. Take a look at your modern day motherboard, and look around the processor, you can see how many capacitors they use to filter the power supply juice from.
