RE: AMT airstart Mercury help!
Hi,
If the EGT value jumps it's offen a problem occuring by a bad wiring of the plug. Please check if the wirese to the plug connection are of the right thickness and if the connection made correct.
Please for my information what type of engine is it exactly.
- Mecury airstart
- ECU type (version number and software release)
As stated in the manual early versions had a problem with the direction of the servo movement. Please check if the transmiter controls the servo in the correct way. If not please reverse servo direction.
Also check if all wires of the plug are disconnected for the turbine the EGT is normal.
Greetings,
Ray
AMT Netherlands
Electronic Designer
