RE: YS 170 DZ CDI
Hello Brett,
Sorry, I did not how many errors I made when typiying on the previous post.
We had in our team an engine with a bad hall sensor, and that, can be an intermittent problem for sure, hope that's what it is, the only thing to remember is, the regulator adjustment might change either a little or a lot, engines tend to be quite different here between CDI or the glow plug.
May I suggest, put a wire on any of the engine mount bolts and use it as ground and just make a conection for the positive on the plug? so you don't have to open a hole on the fuse, what about this, use an old servo extension, use two wires and leave the other side of the conector out somewere so you only use the opposite end of the extension from the glow driver, the conection itself will be the switch, but needs to people.
Hope this helps.
Regards
Alejandro P.
