RE: SAITO FA-80 numbers ?
Kostas, congratulations on the scoring the .80, I have one of the high compression ones and a newer plain one, The high compression one turns a MA Scimitar at 9,900 on 10% WildCat fuel with 18% lube. The high compression is not a problem, it demands respect and when given that it is a fine engine. I also have a high compression Saito 1.50, now that is an engine that can hurt you if you screw up.
