Cox Black Widow
Hi Everyone not sure if this is the correct forum to ask these question.
I havethree questions.
1.The filler tube at the top of the tank is loose, in other words it rotates and floats up and down is this anything I should be concerned about is there a fix
2. The piston seems to have a bit of slop in it when I rotate the crank back and forth at TDC, what to do.
3. Anyone know where I can get replacemant cylinder and piston for a pre 1996 BW, I would like to replace on both engines
