RCU Forums - View Single Post - 20C 2000mAh 3s1p 11.1V - Help Charging?
Old 04-05-2011, 03:43 AM
artistic-aero
artistic-aero's Avatar
Default RE: 20C 2000mAh 3s1p 11.1V - Help Charging?
Yes, thats about what I was asking in the beginning, the pack was charged at 2.0 through a balancer and took 16+ hours and discharged in under a minute. I then removed the balancer and it was charged in 1 hour and a bit. The pack discharged in... just under a minute. So I borrowed another battery pack and that discharged in 8 minutes. I then recharged it through the same set-up without the balance and it took 1 hour and a bit and discharged again in 8 minutes. I'm guessing the batteries are duff. Next step is to use the balance. I have a feeling all will be well there again. Guess its process of elimination and process of buying-more-batteries. Hurray!
