RE: CARF-Models P-47 Thunderbolt
Hi, again, Richard
I've decided to modify the Moki with an electric fuel pump system from APS, the the APS Power Fuel380, which also has a Venturi system for improved distribution of fuel to the cylinders. This means extending the carburetor approximately 4,5 inches backwards, through the firewall, so the throttle servo setup must be modified. As far as I've seen from the pictures, this should be straightforward?
By the way, approximately how many working hours will it take you to finish this ship?
Best
CARF Pilot
