Metal Gear Servos & Loctite
Take a dremel with a thin cutting disk and make a deeper slot. You will probably need the thin fragile type, not the tuffgrind disk. Then go a specialty fastener shop and get socket head screws. At least that's how I solved the same problem.
Tracy Hill
