Old 04-13-2011, 03:13 PM
frankld8
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: I build a transmitter to find lost planes in corn fields.
It works with a reciever that has a directional antenna when the antenna is pointing away from the plane you will get a weak beep when it is pointing in the direction of the plane you will get a strong beep and the closer you get the strong the beep. As you get closer you will turn the gain down on the reciever to pin point location of the plane. I have only used this transmitter on dog collars the range is 12 miles line of sight thats clear path with no obstructions and 2 to 3 miles wooded,hilly conditions.
frankld8 is offline
