ORIGINAL: Rocketman320
In this thread, I want to concentrate the discussion on the lightweight silk covering techniques with either wbpu, glue, or resin. I have three planes to cover - 2 foam and one balsa. I am looking for the best method to achieve a lightweight, strong, paintable surface that will yield an excellent gloss finish when painted. I've decided against glass and resin (weight) and liquid sheeting (fumes) A few questions:
1. What are the best methods so seal the balsa and foam?
2. Wbpu or glue - pros cons?
3. Silk and low viscosity resin -has anyone tried this?
Thanks in advance for you time and information.
Are these open (built up) structures or closed surfaces?
You will have to sand the surface to prep for paint. When you sand the silk it will fray. You can get glass fabric (0.56 oz/yard) that is just as light or lighter than silk. Also, the resin will chemically bond to the glass via the finish. The silk will only get encapsulated. In my opinion, light glass and epoxy will seal the grain and cells (foam) best. If you spritz the balsa with Rave hairspray (aerosol can) that balsa will soak up less resin. This trick doens't work with WBPU because it will disolve the hairspray (water based).
