Hitec Eclips and Spectra
Hi Guys. I read some of your problems. Very interesting. However I have one I cant figure out. I have been using my Hitec Eclips with the Spectra moduel for the past 2 years on all channeles and they all work fine. The problem I am having is that since I started to use the transmitter I haven't been able to land a plane with the engine running. At the present I have 7 different planes in the memory. From trainers to Pattern ships. What happenes is that when I am comming in once the throttle setting gets up to the half way point the engines quit. Yet on the ground you can count the rpms without the engines quiting. It only happens in the air. I have sent some e-mails to Hitec and they say if it works on the ground then it should also work ok in the air. Yet it dosent. Any one got any ideas'as to why this is happening?
