RE: Redcat Racing Tornado Thread
sounds like its your idle and throttle linkage... if your motor isnt reving up good that is you problem then when u let off it kills cuz your idle is set to low... when u first start it does it idle? what are ur needle settings on your carb? the highspeed should be 2.5 and low speed flush with the collar. set the idle up until it idles stable. make sure you have good gear mesh. check the conditon of your gears too. if that doesnt help anything make sure all of the dogbones are in place and if everything looks good and the throttle servo functions properly take out the motor and take off the clutch. look to see if the shoes are oval shape or circular and make sure the spring is in tact. let me know how things turn out
