ORIGINAL: advanced builder
I learned something great. I need some for bullhead fishing. Thanks for the imfo. Justaddwata Can you use that in some of the small scale outboards?
You mean small scale as in Mercury 2hp or 4hp or small scale as in Zenoah with a leg?
I do not believe it is recommended for proper outboards but I am wishing I had some in mine as I did not drain it of fuel 2 seasons ago and I am sure it will need some work. Personally I would use it but it would make for a more expensive day out. I will certainly be using it when I store the outboard next winter.
As for Zen outboards it should be fine as long as it is not highly modded - if modded - check with the motor builder as to what they recommend for fuel and oil.
