ORIGINAL: drumbum
And if you kill your 4-Site airframe there is a multitude of aftermaket airframes for your gear.
James
Do you have any links?
The best Micro 3D plane I have ever built and flown is a lightened (use 2 MM foam instead of the stock 3 MM, use RC Canopy glue and UHU where possible) version of the Donuts Models Micro Aito. I built one using the power system out of a Eflite Micro Beast that came in at 53 grams less battery. The second one used the 4-Site components and an AP05 on 2S with 120 MAH Lipo. That power setup makes more than 100 grams of thrust and my plane came in at 48 grams (less battery) ..it is a BLAST to fly. Doing rollers 6" off the gym floor is a cinch with ths plane. Edges really nice too. James
