ORIGINAL: txshan130
Hi Bob,I plan on trying it back on the test stand this weekend with the Bubble Jett tank and in the meantime buying an aluminum motor mount as well....I think you said the aluminum mounts for the OS 46 will work.Will this one work? Guess my question really is about the bolt hole spacing for the Jett 56 vs the OS 46 series...is the spacing the same since the OS mount is pre-drilled? OS 71913100 Motor Mount 40-46FX/50SX/46AX/55AXThx, Brian
Yes, that should work.
The bolt hole pattern is the same.
