ORIGINAL: SpaceCowboy
With the carbon fibre fuselage you cannot use the regular 2.4 Ghz receiver in it.
You will need the special 2.4GHz rcvr made for CF models.
Mine has a 72Mghz PCM RCVR with a whip antenna & MOKI 1.8 with internal pipe.
Like was said above it has a high wing loading and can't be forced into the air and you need to keep the power up during landing.
IE: Fly it like the real thing.
Hi Fuzzy ; Awesome finish !
What are you doing about a pilot ? I need a pilot for mine and have not been able to find anything suitable locally.
