RE: DLE-111 first start... warranty used, but things are looking good.
If the prop just broke on its own or because of loose bolts the engine most likelywould haverevved up untill the ignition rev limit was reached or reed valve float occured. Quik shutdown...most times no engine damage. Maybe there was a extra screw loose inside! Capt,n
