ORIGINAL: Justflying1
Hello i am building a ESM Spitfire 72.5 inch and would like some recommendations on engines. I would like the plane to sound like a plane. I would also want the engine to stay in the cowl and not exposed. Should i stick with 2 stroke, 4 stroke, or gas. What size would you recommend. Please keep in mind that this plane will be flown as a scale plane and no 3d will be performed as i believe if you want to do extreme aerobatics you build a plane to suit. Your help will be much appreciated.
I have the ESM spitty and orignally had an OS 1.20 Surpass III pumper. It flew well, but was a bit underpowered. I now have a Saito 1.80 installed and it flies her great, but is a bit fuel thirsty. IMO, the Saito 1.50 would be a very good match.
