Can 4ch Tx Slave for 6ch Master?
Hi Chall,
According to what I read from you, you found the PPM-OUT-signal on your slave Futaba TX. Check with the scope if it's a positive or negative pulse. Check on your Airtronics master TX for the PPM OUT-signal. It should be of the same type as the OUT-signal of your slave. If it's reversed compared to your slave TX, then you should reverse your slave signal.
Contact me eventually via the E-mail addres mentioned in my website. Perhaps we can sort it out...
Olivier
