PPM or PCM, single or dual Conversion ?
I use a JR radio with both single conversion JR recievers and FMA Dual conversion micro recievers in my electric planes... never had a glich with either. I would check your electric motor/speed control systems to see if they are leaking interference. I assume you have good capacitors correctly soldered to you engines + - and case. Good luck
Dan
