Hype MX2 first flights.
Ok so I have three planes right now, a 63" extra 300 gasser, a 55" electric foam cessna, and this new MX2 foam electric. So I have pretty fair experience in flying and can handle some fair manuvers in the air. This new MX2 is totally a handful. I have it set pretty much middle of the road on the throws, but if you just breath on the elevator the thing shoots straight up!!! If you get it flying straight and level it will continue straight and level hands off, but if you little more than breath on the elevtor it shoots up. if you do a small correction on the elevator it will respond correctly and then begin to climb really steep! I need help in figuring out what is going on with it. My assumption is that it is tail heavy?? I have not deal with the CG as it is stock right out of the box and should not fly so iratic. It is impossible to land it smoothly with it flying so out of control and I have flown it four times and damaged the (pitifully weak) landing gear already. Anyone with experience with this bird? Can I get some advise?? Thanks for any help!!
