Nexstar Mini EP is also a good choice. The wing design helps prevent stalling. There is also the Nexstar Select, which has a larger wingspan of 68 Inches. They all come RTF if you dont have a radio, and some are in RXR where all you need is the receiver.
The Select has pilot assist too, if you get goofy with it, take your hands off the stick it will right itself. this system does have drawback, it only works in daylight between 10 AM and 4 PM, if the sun is low it messes with the device and you have to turn it off. I'm looking for something like this in Nitro. I can get one for $379.
