Programming Snap Ailerons on 9C
To program the snap-roll switch:
1. Press MODE/PAGE until your ADVANCE (mixing) menu comes up.
2.Scroll down to *SNAP-ROLL and press the dial.
3. Using the Cursor buttons, click up to MIX>INH and turn the dial counter-clockwise so it says OFF.
4. Using the Cursor buttons, click down to AIL> and input the amount of aileron you want.
5. Click down to ELE> and input the amount of elevator throw you want
6. Click down to RUD> and input the amount of Rudder throw you want.
7. IF you want the snap switch on a saftey, click down to where it says SAFE-MOD>FREE and rotate the dial until it says OFF. Your landing gear switch (make sure your Channel 5 is not inhibited) is now your snap switch safety. Deploying your landing gear (or at least flipping the switch so it would) will now inhibit you snap switch. Retracting them (or adjusting the switch to such a position) will make the snap switch active.
8. For snap direction, click down to DIR-SW-1> and/or 2> and select a switch(s) for your snap direction. Repeat steps 1-6 to set up your other snap directions.
Hope this helps.
