you could also run a bigger prop(more pitch) since your DA(density Altitude) will be a wee bit higher than,,, I would suggest to locate a Density Altitude calculator on the web,,, plug the required numbers in,,, choose a prop,,, take notes of the days practice with the calculated DA, props used and go from there. The data you collect will show all
BV
