RE: Big 500E's 1st flight
I have a lightening 5 bladed head and TF models 700 mm scale blades but had a LOT of problems. I'm not sure if it was the head or the blades. I'll get back to it at the end of the seasson.
The only gotcha I found was that the glue that held the floor and formers seemed brittle. I went over it with some epo grip epoxy. I've found that to be common on a lot of the standoff scale fuses.
other than that I have to say it was the easyest build I've ever done. With four doors that open and the size of the fuse you can get at everything. i could get use to that LOL.
