RE: ESM P47 Build
Hello B7,
I have 1 servo for each elevator, each on a separate channel, (my choice), I used the fitted Push Rod sleeves, but I put a better quality push rod inside them, with solid wire inside that,
I have the air tank mounted in the Belly Pan, under the wing, that way all the air system is on the wing, a few less items to leak, the air valve is a Robart,
the fuel tank is back where it is to ease Trim changes during flight and nose over problems on the ground, although this model is very stable on the ground. the tail wheel is the same as a Du-Bro 957, bought it from HK,
Oldtimer.
