RE: Could not start NIB YS115S
Sounds like it has higher compression that the old 1.10 or .91. If you can pull it through by hand but your sarter will not turn it then it very well may be you need to try a gear reduction starter. Does anyone you fly with have a gear reduction starter you could try?
